  • mannaky 12 posts 60 karma points
    Sep 08, 2014 @ 09:42
    mannaky
    Using external libraries in XSLT - XslTransformException [v 7.1.6]
    I want to use an own library in a XSLT file. However, I always get the following error when I try to save the file.
    System.Xml.Xsl.XslTransformException: Cannot find a script or an extension object associated with namespace 'urn:Ext.Library.SearchHelper'.
       at System.Xml.Xsl.Runtime.XmlQueryContext.InvokeXsltLateBoundFunction(String name, String namespaceUri, IList`1[] args)
       at (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
       at Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
       at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer)
       at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results)
       at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging
    My XSLT file looks like this:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
        version="1.0"
        xmlns:ExtSearch="urn:Ext.Library.SearchHelper"
        xmlns:Examine="urn:Examine"
        exclude-result-prefixes="msxml ExtSearch umbraco.library Examine ">
        <xsl:template match="/">
            <xsl:for-each select="ExtSearch:Search()/descendant::node">
                Id: <xsl:value-of select="@id"/>
             </xsl:for-each>
        </xsl:template>
    </xsl:stylesheet>
    And the class definition looks like this:
    using Examine;
    using Examine.SearchCriteria;
    using System;
    using System.Linq;
    using System.Text.RegularExpressions;
    using System.Web;
    using System.Xml.Linq;
    using System.Xml.XPath;
    using Umbraco.Core.Macros;
    namespace Ext.Library
        [XsltExtension]
        public class SearchHelper
            public XPathNodeIterator Search()
            return GetResultsAsXml(ExamineManager.Instance.Search("", false));
    The strange thing is: When I run umbraco locally on my machine (Umbraco 7.1.6, Visual Studio 2013, ISSExpress 8.0, .NET 4.5) it is working fine. But when I run it on whe web server I get the above mentioned error (Umbraco 7.1.6, IIS 7.5.7600.16385, .NET 4.5)
    Thank you for any help!
    Regards,
    mannyk
    Sep 08, 2014 @ 10:52
    Lee Kelleher
    Hi mannyk,
    I think the method needs to be a static, try this:
     public static XPathNodeIterator Search()
    I'm not too sure why it's running ok on your local machine though?
    - Lee
    Sep 08, 2014 @ 11:25
    mannaky
    Hello and thank you very much for your advice.
    I have changed now the method to static but still I get the same error. Again, it works on local side.
    Regards,
    mannyk
    Sep 08, 2014 @ 11:30
    Lee Kelleher
    Where is your code/class? In a compiled DLL or a file in /App_Code folder?
    (I've heard about an issue with XSLT extension methods not working properly in /App_Code for v7)
    Sorry for asking this next question... are you sure that the latest code is up on the web-server?
    I know it sounds obvious, sorry.
    - Lee
    Sep 08, 2014 @ 13:06
    mannaky
    The class is in a compiled DLL in the /bin folder.
    Yes, I have also checked, that the latest version has been copied on the server.
    Regards,
    mannyk
    Sep 08, 2014 @ 13:12
    Lee Kelleher
    Thanks mannyk.
    The next thing I'd try would be to manually set the namespace for the XSLT extension class:
    [XsltExtension("my.search")]
    Then in your XSLT, change:
    xmlns:ExtSearch="urn:my.search"
    If that doesn't work, then Umbraco isn't picking up the extension class. From there, try selecting "skip error checks" and running the macro on the front-end, see if it gives you the same error.
    - Lee
    Sep 08, 2014 @ 13:57
    mannaky
    Hello and thank you for your help.
    I have tried so (with your example "my.search") but I get the same error (of course now with the message that the namespace 'urn:my.search' cannot be found).
    I have now saved the file using the ignore error function but in the front end I get the following error: Error parsing XSLT file: \xslt\Search.xslt
    Regards,
    mannyk
    Sep 08, 2014 @ 14:08
    Lee Kelleher
    Hmmm... I think it might be a bug in Umbraco.
    There's a ticket on the issue tracker #U4-3425, about a similar issue, but it was fixed in v7.1.2. I'd suggest raising a new ticket on the issue tracker (with a reference to #U4-3425) and see if the core team can shed any light on the issue.
    - Lee
    Sep 08, 2014 @ 14:18
    mannaky
    Okay, thank you. I will reopen this issue.
    Regards,
    mannyk
